Shadow2531
- Jun 13, 2003
When installing perl on Windows, I usually install to c:\usr so that perl.exe is in c:\usr\bin and I install python to c:\usr\bin so that python.exe is in c:\usr\bin.
That usually solves all problems when using #!/usr/bin/perl and #/usr/bin/python.
However this time I kept the default directory of c:\perl when installing ActivePerl. Too many build scripts look for perl files in c:\perl and I found myself editing them too much to point to c:\usr\bin.
When perl and python are installed to the default directories of c:\perl and c:\python repspectively, apache cannot find perl.exe and python.exe if you use a *nix stile shebang line.
I solved the problem by adding ScriptInterpreterSource registry to httpd.conf so apache would look to the WinXP registry to find the paths. That way I can use *nix style shebang lines.
However, this does not help for the cgi extension. With the cgi extension I have to put #!/perl/bin/perl and #!/python/python or apache cannot find the interpreters.
Without installing perl and python to c:\usr\bin , how can I get the cgi extension to work right with BOTH #!/usr/bin/perl and #!/usr/bin/python ?
BTW, the paths to perl and python are set.
The problem does not exist with SSI and the shtml extension, just the cgi extension.
This is with Apache2
Thanks.
Thanks.
