Cousin Patty
- Jul 21, 2005
I need to replace the stock heatpipe on my 680i and I've been looking at some chipset coolers but im not sure what will fit and whats good or not. This is what I was looking at:
For the southbridge:
http://www.petrastechshop.com/encnonfocoso.html
I'd like to keep the solution passive on the southbridge if at all possible. Running out of fan headers and power connections.
For the Northbridge:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835119089
Like I said I dont know whats compatible with the mounting holes on the 680i. What are you guys using on your chipsets for this board? Thanks
