Magik Smoke
- Jun 11, 2004
Anybody here done it? Does it work ok? Do the XM series images load correctly? Any info would be much appreciated.
Arch said:The memory part number you speak of isn't a "hacked" boot rom, its the part necessary for the 2600 series to support 12.3 mainline and higher.
YepArch said:Note, after upgrading the boot rom to the newer version the router MUST run 12.3 mainline or higher.
Arch said:Also, why in the world would you want to run 12.4 mainline code?
Magik Smoke said:Unless you buy the rom from a third party and run cheaper third party flash. Note also that 12.3 is Unsupported for the non-xm non-91 series.
