Mackintire
- Jun 28, 2004
So , I 'm trying to figure out why the previous admin did this.
ASA version 8.2 (5)
In the config I am looking at....
interface GigabitEthernet0/0
speed 1000
duplex full
description Outside Interface - Connect to WAN
nameif outside
security-level 0
ip address 209.xxx.xxx.001 255.255.255.0
But he's created static routes to the internal network using external IP addresses starting at .002 and continuing to .006
Is the some reason you can't or don't want to use map the same IP that is defined to the outside interface to a server in the DMZ? Or is this just a case where he has IP addresses to burn?
ASA version 8.2 (5)
speed 1000
duplex full
nameif outside
security-level 0
