I'm between two options in regard to where to place the modem, router, switch, patch panel, etc.
(1) Utility room with double doors, located inside the house, on the first floor. Inside this room is the HVAC, gas line, etc. There's enough room to mount a shelf on the wall with the hardware stacked vertically, but besides that room is tight.
(2) Room under a staircase with a single door, located in garage, on the first floor. There's plenty of room to mount a large rack but I'd also have to run power to the room.
I'm wondering if I need to worry about temperature variations. The garage is part of the house but it's not actively heated or cooled. Granted, one might argue that the utility room would also be subject to temperature variations also due to HVAC, etc.
Your thoughts are appreciated. Thanks.
