theshadow27
- Sep 7, 2004
alright [h]ard... im trying to take a LM3916 logoritmic LED vu meter chip. and hook it up to 4 or 5 cold cathode inverters. im thinking i can gang together 1+2, 3+4, etc, and use a transistor of some sort to switch the 12v. also, i want it to be most responsive to base, so i need an inductor of some sort.
specificly i want to build this myself, so:
-any thoughts on how many coils the inductor would be
-any thoughts on what type of transistor i could use (im thinking MOSFET?)
-ganging the outputs on the 3916 together.. could that be bad?
-instead of ganging, could i make the first one do 8v and the second do 12v for a smoother effect? i know inverters dont like low voltage, but i know they work at 10v and even 8v
-anything i need to know before i throw this on the output of an amp
EDIT: the same chip, but a diffrent project, im having 2 of these drive 2 rows of LEDs, but i want to use BI-Color LEDs. sence the chip sinks the LEDs, i figure that if the LEDs are red, orange, or yellow, they will alwase sink the same current, and alwase be the same brightness. but heres where it gets complicated: i want the LEDs to be yellow untill the 3rd LED lights up, then they change to orrange (all of them), then when it hits the 6th one, they all turn red. i would just throw a transistor on the 3rd and 6th pin, but i dont want to throw off the current draw for thos LEDs. so do i need to get 2 more (top and bottom) 3916 chips? or should i get a quad comparitor and hook that up?
