So my COH (original version, have not gotten any patch yet and am not even sure if there is one out) has been running pretty crappy. Check out my sig - do I not have a good enough system to turn Post Processing off and run everything on "High" at 1280 x 1024 (note, NOT Ultra on anything)???
When I do the Performance test with these settings, I get:
min: 25
average: 54
max: 156
Sounds good, right? But then I load into the game and things get all choppy, anytime I rotate the camera it seems to lag, and it just generally runs smooth for a few seconds then stutters, runs smooth for a few more seconds then stutters again.
Anyone else having this problem? Can anyone with a similar system tell me what settings they're running with? I feel like I should be able to run this game at higher settings with the rig that I have...
Thanks in advance!
min: 25
average: 54
max: 156
Thanks in advance!
