FallenMystic
- Jan 20, 2006
Greetings all,
I'm in the process of building my first WC setup and I'm trying to make it out of as much stuff as possible from your typical hardware store.
One of my first idea's is that I want to build in a dranage system by using a T or Y splitter and an on/off valve. The ones that look to be the best quality are brass compression fittings; so my question is, what are your feelings on compression fittings? Is it something you would feel safe/comfortable using in your setup or is it something you would aviod at all costs?
Thanks in advance for any input.
Many Thanks,
Fallen Out
Many Thanks,
Fallen Out
