the_transporter
- Aug 19, 2004
My computer (see system specs) shuts down only during gaming (load). I reset the bios back to stock settings (stock voltage, stock cpu speed, turbo boost disabled), but the shut down problem still persists. When I boot my computer back up and enter the bios, it says somewhere along the lines of the system shutting down due to overclocking.
I would like some advice and insight on which part could be the faulty one. I am thinking it is the motherboard and I plan to replace it with the Maximus III Gene (if it is). Do you guys think it could be the CPU or PSU?
Thanks.
Thanks.
