Hi all. I just got back into folding...used to run in back when it first came on the scene. I don't seem to remember the name I used, it was when the team was first started. Does Stanford purge for inactivity?
Anyway, onto the machines.
I have a e6400 and e6600 both running 2 consoles as a service, allowing greater than 5mb units, with -forceasm and -advmethods. Is this the best configuration for the gear?
I am about to add a 3.0Ghz p4 w/HT to the mix and was wondering how I should set it up. I am assuming a single console, but should I accept larger workunits?
Thanks for any help!
