Currently i'm using a Coolermaster ATCS 840, and while it's fine, it annoys me that it sticks out so much, and that cable management is a bitch... and that I can't place a larger radiator on the top.
So i'm thinking the following.
Lian-Li PCX series, since they are relatively shallow, and I can front mount a 140.3,
I'm also considering FT-02, since I can raise it to clear the lower part of my desk, and depth will not be an issue.
Desk is west elm cadman (2x 48")
Although buying a PC-X series appears to be cost prohibitave.
Any other suggestions will be appreciated, and for those that have ravens or fortress's that have water cooled, how effective are those magic cool radiators with the stock fans?
At most my setup may become gtx670sli + 2600k, but for now it's just a evga gtx670ftw with ek-680 block, and an xspc rasa that is going into this build.
Further since to mount that radiator on the floor of the silverstone fortress I'll have to give up the hdd cage, what options are available that will allow me to mount 4x3.5 drives, and still remain quiet.
I primarily water cool for silence, overclocking is just a fringe benefit.
