coolchu001
- May 27, 2007
Got one of those Stacker 830SE today (from frys for $122 shipped/taxed).
Just as I've thought, the sanyo denki would fit at the top without any major modifications
All I had to do was to remove the PSU backplate, the two side panel locks, and bend the top 120mm brackets upwards. Simply position the Sanyo Denki and slide right in .
I got the Sanyo Denki from frozencpu but it is now sold out, but you can also find it at performance-pcs.com
It's a very cheaply priced all in one liquid system.
FYI these are the same units Falcon-nw puts in their Mach V PCs.
Here are some pics :-D (Cant wait to rebuild my computer into this case, also got a new Q9450 CPU )
I'll probably swap out the stock Denki fan with an Antec TriCool since it has an annoying wind to it...
Oh btw, the case came with a set of wheels and a bonus aluminum/plastic hard surface CMStacker mousepad :-D
