ToastMaster
- Nov 2, 2005
Anyone know by chance how easy it is to remove the clear plastic side piece that holds the 4 fans in place?
Tysterisk said:@ azure: Try to get some Panaflos, L1As if you're into low noise. Alternatively, the U1As are loud as balls but pump out some insane CFMs.
@ clesven: Are you sure you have the standoffs in the right places?
