This is going to be hard to describe but I'll try.
Basically, I have two harddrives.
Raptor X 150GB (Same as yours)
and
Maxtor 500 GB
Chapter 4 - Unique Features
4-1 Xpress Recovery2
Basically, this is the step where I installed Windows XP and Partitioning the Hard Drive.
I think I did something wrong in this process because after I loaded onto window XP and checked "my computer", it only showed 1 harddrive.
Here are some screen shots to show you my confusion:
I think I formatted the Hard drives wrong or something because the "partition" says I have 120gb unallocated.
And I think it's the maxtor drive in that thing... isn't it suppose to be my Raptor?
Also, I ran coretemp and here's a screenshot. The cores were reading from 34-38 degrees C.
What's with TJunctions reading 100 degrees C though? Is that bad?
and
Maxtor 500 GB
