I just put together a new C2D system with Corsair TWIN2X2048-6400C4 modules. I plugged inthe specified settings for the RAM (4-4-4-12 @ 2.1v) in the bios and it booted up. However, I overclocked the computer - keeping the RAM at the stock 400MHz - pushing my e6400 to 3.2GHz. It did fine and went through 24 hours of Orthos small FFTs no problem. Then I ran memtest86+ and got a number of errors on assorted test (mostly 2, 3, and 6).
I figured it was probably due to the overclock giving insufficient power to the DIMMs or stressing the northbridge too much or something of that nature so I dropped everything back to stock and ran memtest again with the same results.
I'm currently exchanging messages with the Tech Support Express at Corsair to hopefully get an RMA approved, but it's rather inefficient. I was wondering if any of you guys had any suggestions on other things to try?
Specs of the rig are in my sig and based on both the bios monitor, speedfan, and coretemp none of the temperatures are particularly outrageous even when overclocked.
