I've got 4x2 1066 Corsair Dominator DDR2 in my system (see sig) that is supposed to run at 2.1V at 5-5-5-15-2T. So I set my BIOS to run at these settings, specifying 2.1V, even though it's pink in my BIOS settings. I assume this is just my MB's way of saying that this setting could be bad for some RAM, but mine is supposed to run at this voltage, so I go on.
Now, the problem. I set the other voltages for the RAM to 1.05V. But every sort of test utility I've used, i.e. Hardware Monitor, Easy Test 6, CPUZ, etc. has listed the rest of the subsidiary settings as 0.9V.
Is this a problem, or am I OK? I'm just a bit concerned that my RAM isn't running at the voltages I set for it. Any ideas?
