I want to control my fans through a fan controller, while still monitoring the RPMs of each fan through the motherboard. Would separating the yellow wire from a 3-pin extension(as shown in the picture) and connecting it to the motherboard do the trick? I'd try it, but I want to make sure I don't fry anything.
Also, do RPMs scale the same as voltage? For example, will a 2000RPM 12v fan run at 1000RPM at 6v? Or is it different with each fan?
