I have a straaaange problem. First of all, I have an 8800GTS 640MB that is NOT OC'd. Periodically, my GFX run very poorly. To give you an idea, I get ~20 FPS in the beginning scene of 3dMark06, and it doesn't JUST effect 3dMark06... it happens in games as well. When the GFX run correctly, I get ~52 FPS in the beginning scene.
Here's how it works: I turn the computer on, I get crappy performance. I restart, I get crappy performance, I restart again, I finally get good performance (night and day difference here). Sometimes I have to restart several times. It seems VERY random and I'm not changing anything between restarts. Now once it runs well, it runs well until the computer restarts or turns off, then I have to go through the restart sequence until I get a "good" restart.
I'm nearly 100% positive that it is NOT a driver issue. I've reformatted 3 seperate times and installed 3 different drivers each time to no avail.
That leaves it down to one of two things: the graphics card or the motherboard (P5B deluxe).
I've tried to change all sorts of graphic settings in my BIOS, updating the BIOS, locking the PCI express frequency, and messing with random other GFX settings in the BIOS. Finally I just went to the stock 266 FSB and started up from there.
Now my applications run fine. Absolutely no hitches with stock settings and I've been able to restart the computer without it running poorly after the restart.
So what I'd like to know is... WHY IS IT DOING THIS? I never expected my CPU OC to effect the graphics card in such a weird way. Is there any other possibility that I've missed that might be causing this? Maybe my GFX card is acting funky but I don't know how to test that other than plugging it into another computer, which I don't have.
