I think the premise of this question is slightly flawed.
VMware itself uses very little resources, so it could care less what CPU you run it on as long as it is supported.
Physical CPU resources are shared between VMs, thus all VMs need to share the clock cycles as well as available cache (at least in most basic terms). Whether your VMs would benefit from more CPU cycles or more cache depends on what you are doing with them. However, while there will certainly be a difference in performance between a 512K cache and a 6MB cache (per core), the practical difference between 4MB and 6MB is likely to be only noticeable in benchmarks rather than observation.
