Heliocentrical
- Mar 28, 2005
Hello, needing some advice on a cmos battery for a laptop. It's a standard CR2032 but it wasn't installed in a PCB holder. It was shrinkwrapped and glued next to the memory slots inside the laptop. There are two metal leads glued to the battery on either side. I called Frys and Microcenter and no luck. EBay has a bunch but they are all 15 days shipped from Hong Kong. Should I try and make my own? Just get a new battery, glue on the leads somehow, and insulate it with electrical tape? What do you guys think? Thanks for the advice.
