Hi there - I'm looking at putting together this system:
https://secure.newegg.com/NewVersio...ber=7462628&WishListTitle=Potential+ATX+build
Intel Q6600 G0 $280
EVGA GeForce 8800GTX 768MB $550
Abit IP35 Pro $178
Crucial Ballistix 2GB (2 x 1GB) DDR2 800 (PC2 6400) $99
HITACHI Deskstar 7K1000 1TB 7200 RPM SATA $360
ASUS 18X DVD±R DVD Burner SATA $33
ENERMAX Noisetaker II 600W PSU $126
LIAN LI PC-G50B Black Mid Tower Case $90
These are my purposes for it:
I already have the hard drive and mouse. I actually have two of the hard drives - haven't decided if I'm going to raid them, or use one as a external storage/backup solution, or something else. Still need to select a keyboard (I'm swithing over from a laptop). Also, I'll be adding in one of these bad boys: http://www.lavalink.com/index.php?id=232 (already have it as well).
I also will need to get a TV tuner card - haven't selected one.
The case and PSU were fairly random. I have used Lian-Lis in the past and have liked them. If there's something cheaper I would love to hear about it. Years ago (6-7ish) I used an Enermax that looked nearly identical to the one I have selected, which is why I have that one selected. But now I'm thinking that maybe I should go with a modular supply like the Corsair HX Series CMPSU-520HX 520W $108. It's a little wimpier but I would think that 520W would still be enough, right?
Haven't chosen my monitor yet - will probably be a 24" and there's a good chance I'll get two. I haven't decided on XP vs. Vista yet either, but probably Vista.
DVD burner was random - it was the cheapest with SATA and lightscribe.
I'm planning on buying the CPU from somewhere that guarantees G0 stepping. I'm initially just going to use the retail heatsink as I don't plan on initially OCing.
The video card is probably massive overkill. My CAD stuff runs ok on my little Radeon 9000 card on my 4 year old laptop. But with a much bigger monitor and the potential of gaming it seemed like a good (but expensive) idea.
So - how does it all look?
Thanks!
Intel Q6600 G0 $280
Abit IP35 Pro $178
- eCAD
- SPICE (electronics simulation, the most CPU intensive thing that I do)
- 3D CAD
- programming
- movies/music
- maybe occasional gaming - I haven't gamed in years though so that's at the bottom of my priority list
Thanks!
