I am wondering if anyone else has this issue or knows what this is.
I have a dual boot machine. XP and Vista both 32 bit.
Hardware: Asus Crosshair, AMD 6000+, 3 Seagate 250 HDs running in RAID 0 on the onboard Nvidia raid setup
When I use Vista, I get an annoying whistling noise that sounds like it's coming from the hard drives. It gets louder when I run programs to a point where it's rather annoying. When I load up Crysis, it gets even louder like a scraping and high pitch noise and it's clear that it's the hard drives making noise. This is not like a regular hard drive being accessed noise.
When I use XP it operates fine with no issues. I play Crysis on XP with no noise issues.
I have run tests on the drives to see if any are bad but nothing shows up.
I don't think it could be a bad drive because it's only doing this when using Vista.
Anyone?
Anyone?
