Hey for those of you you have CS Source, have you ever had a problem when the game will just freeze (even when nothing intensive is going on), then after say about 10 seconds or so, it will unfreeze. When it comes back though, it shows all the items you have on the right side of the screen as if you just bought them again..
If it wasn't for that, I'd think I was having some kind of heat related issue, or some other instability.. but it definately seems more game related than anything else.. I have no other problems with any other game.. and so far I've only seen this happen when playing office.. granted I spend most of my time on a 24/7 office server, but when I do go to other servers, and play other maps, I haven't seen this happen.. even when playing office on another server..
it's pretty random, and I can't duplicate it..
I've run numerous stress tests on my rig, and haven't had any problems. rthdribl runs no problems at all, and all other games have been solid.. even HL2 ran without a hitch.. just CS has had this happen..
if it helps, I listed my specs at the bottom..
I'm running WinXP SP2 on it, using the 5.10 chipset drivers, and the 67.03 vid card drivers..
I'm running CS:Source @ 1280x1024 with every setting on High, Reflect World, and 4x AA/8x AF..
My framerates are good, and my temps and voltages are definately above par..
When this does happens, it's almost like the server got hit with some system lag, and the game has a problem recovering.. last time it did happen, I asked if anyone had any lag just then, and a few ppl did.. thoughts on this one?
MSI K8N Neo2 (1.4 official bios)
A64 3500+ Newcastle w/ Swiftech MCX-6400V
1 Gb OCZ PC-3200 Platinum Rev 2
Gainward 6800GT Golden Sample (running @ ultra speeds)
Audigy 2 ZS
PC Power and Cooling 510 Deluxe
Hitachi 7k250 80Gb SATA HDD
2x WD WD800JD 80Gb SATA HDD in RAID 1
Lite-On 52x32x52 CDRW
NEC ND-3500 16x DVD Burner
Lian-Li PC-65
6 80mm fans on a Fanbus (4 Blue quad led)
Dual 12inch Blue Cold Cathodes
Matrix Orbital 20x2 USB LCD Display mounted in top 5 1/4 bay
Creative Inspire 7700 7.1 speakers
All cables either rounded or sleeved
19inch and 17inch CRT Monitors (ones a Mag and the other a Dell.. need some dual Dell 19inch LCD's)
Razor Diamondback 1600 DPI mouse
Icemat Rev2
Saitek Gamer's Keyboard
Audigy 2 ZS
Lian-Li PC-65
Icemat Rev2
