Well, this has been a problem that I've had with every pc. But I'm not sure if there's a way to fix it. The deal is that the cursor blinks weird when another animation is been displayed. That includes GIF animations and FLASH animations as well.
For example, when I type replys here at [H], I see that the cursor blinks way too fast, or sometimes skips. It's the Newegg banner on top. It gets annoying when you write a few lines, and when you go back to check your grammar, it becomes difficult to find the cursor again. But for this issue, I have found 2 solutions, even though they are not as I would of liked:
1) Scroll down/up enough so that the animations are not seen. This gets the cursor speed back to normal.
2) Click with the mouse directly where I want to type. The cursor still looks somewhat invisible, but at least I know where I placed it.
So yeah, I was wondering if you guys experience this as well. Or maybe if you have found a solution for it.
THX
THX
