aeonrevolution
- Aug 30, 2004
Hey guys. I'm guessing this should be an easy fix. I successfully got this little D Link guy working off my router and all my computers can connect fine. Whenever I try to connect my Vizio 70" the problems start. The D Link unit shows up in the Wifi scan, but when I enter the password it sits there thinking for a minute then says "Unable to Connect".
I tried googling it, but I'm getting mostly reviews and lots of unrelated info.
If anyone has some tips, lemme know. I tried going in and setting the ATT box to switch to the D Link instead of the router, but I'll be damned if I can figure out where the network settings are in the ATT menus. I dunno if it even really matters whether I try to use the TV or cable box to connect in to the internet.
