http://www.compusa.com/products/product_info.asp?product_code=320011&pfp=BROWSE
if this is a repost than just shoot me
In order for jumbo frames to work, everything between where the transfer is starting and where it's ending must support jumbo frames.UltimaParadox said:What if you have a router that is connected to the switch for internet access, then all your computers are connected to the switch as well. Will all the computers directly connected to the switch that support jumbo frames, continue to support it as long as its transfers between computers on the same switch?
UltimaParadox said:What if you have a router that is connected to the switch for internet access, then all your computers are connected to the switch as well. Will all the computers directly connected to the switch that support jumbo frames, continue to support it as long as its transfers between computers on the same switch?[/QUOTE
As long as the communication is b/t two computers directly connected to a switch that supports JF's then yes the communication can be but your internet traffic will not since Im not sure of a home internet service that suppiles enough bandwidth to matter.
Darth Millennial said:As long as the communication is b/t two computers directly connected to a switch that supports JF's then yes the communication can be but your internet traffic will not since Im not sure of a home internet service that suppiles enough bandwidth to matter.
