I've got a pile of miscellaneous stuff here in the corner of my room that I don't really need; a lot of it will probably be thrown out if nobody wants it, so please PM me if you want something and I've got it priced too high. Everything is in used but functional condition, except where otherwise noted. All prices include shipping. Heatware references under DanK, ebay under tlunsegr12.
Things I want in trade (or in partial trade, PM with offers)
256MB PC133
256MB RDRAM (speed unimportant)
Things I have to sell / trade
(1) 92mm, 110 CFM Delta
Delta FFB0912EHE, 92x38mm, 110 CFM. Same as a Vantec Tornado. Comes with a 3 --> 4-pin adapter and a 92mm grill. $10.
(1) 16MB XD flash card
Came with my digital camera, barely used. $8.
(1) HP cd-writer 9300 series
(1) HP cd-writer 9500 series
One burns at 12x, the other at 10x. (They both look the same, so only one is pictured.) $9 each.
(2) Zalman CNPS 5000 Athlon / P4 heatsinks
All copper; requires motherboard mounting holes, and comes with the required mounting hardware. No fans; would work great with 60mm --> 80mm fan adapter. $9 each.
HomePNA phoneline network adapters
Can't wire your house for ethernet? Use your existing phone lines instead. 2 Broadcom adapters that work at 10Mbit, and one AMD adapter that works at 1Mbit or can function as a 10Mbit ethernet adapter. Works under both Windows XP and Linux. $8 for the set.
(1) Conexant softmodem
$3.
(1) 36" round IDE cable. White. 80-conductor, 40-pin. $3.
(1) 10' parallel port printer cable. Grey. $3.
(1) Dell floppy disk drive, no faceplate. $3.
256MB PC133
$3.
