My QNAP somewhat failed so I have to pull the data off. Basically to use it again I must reformat the drives but in the mean time the data is accessible via FTP. I have about 5TB of data so I bought 2 x 3TB drives and have begun the painful process of transferring 5TB of data @ 3.5Mib/s (max transfer speed in this situation).
I filled up the first 3TB drive and I moved to the second. There is something I needed on the first drive so I plugged it back in however 1 of my 2 folders is empty. Windows 8 reads the drive as "212gb free out of 2.72TB". Folder 1 reads as empty and when I click on it it says 'folder is empty'. Folder 2 says it has about 980gb which sounds right. Within Folder 2 there are probably 50 other folders that I randomly checked and they appear to be fine.
When I plug it in to my Macbook it says it can't read the hard drive. When I plug it in to my Windows 7 machine it reads the drive, opens Folder 2 fine and says Folder 1 is not accessible. At first it did not read the drive but I re-plugged in the USB cable and it found it BUT it said it needed to initialize it. I re-plugged it in the last time it read Folder 2 fine and said Folder 1 wasn't accessible. I tried to transfer ~50gb out of Folder 2 but it froze and isn't visible in Windows anymore. After I'm done posting this I'm going to replug it in again.
The two new 3TB drives are Seagate NAS drives.
Any thoughts on what I can do to avoid wasting another week transferring this data for the second time?
