I've been trying to OC this machine, following the stickied guide I lowered my multiplier so I could find out the limit of my RAM. I purchased this OCZ memory for my new build, which should clock to 250mhz without any issue right? Well when I do Prime95 starts giving me the rounding error, you know 0.5, when less than 0.4 was expected.
System specs:
AMD Athlon 4400+
2x OCZ Platinum Edition 1GB DDR500
HIS X1800XT 512
Temps
CPU - 28C Load - 22C Idle
PWM IC - 34C
Chipset - 42C
Voltage:
CPU 1.32v
LDT Bus 1.19 (what is this?)
DRAM 2.65v
System specs:
AMD Athlon 4400+
HIS X1800XT 512
Temps
PWM IC - 34C
Chipset - 42C
Voltage:
CPU 1.32v
DRAM 2.65v
