Hi everyone,
I was doing some internal rewiring in my dad's right today, and I went to turn it on while the case panel was removed to test all the fans. CPU and chassis fans worked, but the fan on the GeForce 5600FX was dead. It wasn't spinning at all, and it was indeed plugged in.
I checked VGA temps under the Nvidia drivers settings, and the temp was about 64*C idle. When that rig was also used by me, the temps were the same and would climb to about 80-90*C under load. At the time, I didn't know whether the fan was dead or not.
I have a couple questions:
1) Could dust be causing the fan not to work?
2) If the fan is indeed dead, do you have any recommendations on replacements that are cheap (under $30) and will work pretty well? Newer games aren't played much on that rig anymore, so there's not much of a load. I'd like any replacements to be installed easily with no modifications.
The video card is BFG Tech Asylum, so could I just RMA a fan, even though the video card was purchased in July 2003? I've never had to RMA before. Should I even bother trying to RMA, or just buy a fan?
Thanks.
Thanks.
