dealmaster
- Jul 12, 2007
Hey guys,
After encountering BSODs and general system instability for a while, I finally narrowed the problem down to a bad memory stick. I've started the RMA process, but I had a question about my system setup.
I have G.Skill Sniper DDR3-1600 RAM and the bad stick sits underneath one of my Scythe Ultra Kaze 38mm fans on my heatsink. It likely gets little to no airflow at all. Is it possible that this environment caused the RAM to heat up and die an early death? I don't recall getting BSODs when I first bought the RAM, but that was months ago and I can't say for sure.
If you guys think it's possible that heat killed it, I'll pick up some Gentle Typhoons and remove the thicker fans, hopefully that'd improve the airflow over that stick. If you don't think it's a problem, we'll chalk it up to a defective stick and hope for the best when the replacement arrives. Thanks!
