Private_Ops
- Jun 4, 2007
Running windows 7 64bit.
Computer will restart itself after it shuts off the display from being idle. Checked the event viewer, turns out its a BSOD. Recently swapped motherboards but, putting two and two together it was doing the same thing on the old board (Went Z77 to Q77), but I never did check event viewer on the old board.
Searching a little, it appears to be video card related. Currently using a Gigabyte 550ti with the 332.21 drivers.
Anyone have any advice? I'll try updating to the latest.
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000116 (0xfffffa800741c010, 0xfffff8800ff9dbbc, 0x0000000000000000, 0x0000000000000002). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 040714-5834-01.
