Hey guys! I thought that this was kinda interesting and maybe worth mentioning....
Last night I was talking with a friend and we ended up getting in a little debate over which was better or if there was even a real performance difference between using 3/8" ID hose with normal 1/2" OD blocks or using 1/2" ID hose with the same 1/2" OD blocks. He was saying that using 1/2" ID hose was pointless because blocks with 1/2" OD fittings only have an ID of 3/8" which would mean that the flow is restricted at that point and, because 3/8" ID hose is easier to fit into a case, it is best to just use 3/8" ID hose on blocks with 1/2" OD fittings. I was basically saying that even though the ID of the barbs is 3/8", the 1/2" ID hose allows more water to get to that particular barb in a given amount of time compared to 3/8" ID hose; thus, allowing coolant to move more quickly from block to block and to the rest of the parts in the system--resulting in a slight performance advantage.
Now, uhh, who was right...?
...Also, how much of an advantage is there really with 1/2" ID hose over 3/8" ID when using 1/2" OD barbs?
