Hey guys, first off thanks for any responses you may have. My main thing is i have an older quad athlon II 620 quad that is pumping 100 watts, its in my HTPC that is on 24/7 and is used for our ceton cable card tuner.
I was looking in to trying to get something to help cut back on power and that would be a little faster on video playback.
Right now im using only 4gb of ddr2 and the onboard radeon 4250.
Im looking at either moving to an intel pentium G620 CPU its a 65 watt cpu or even maybe spending more for the G630T being a 35 watt CPU and using the HD2000 graphics.
Going to be using
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157256
Second Choice is the AMD A6-Series AD3500OJGXBOX Triple-Core A6-3500 APU
Runs at 2.1ghz with 3 cores and the higher end GPU.
And
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1967886&sku=A455-4016
The Intel system is going to run me about ~160, ~180 for the 35watt CPU i have everything else.
The AMD system will run me about ~205
The main thing is that im trying to do is handle the quad stream HD, along with blu ray rips, ill probably be using my older 60gb ssd as the windows drive and leave my 1tb in there for the storage. Im just wondering even though my older CPU is a quad do you guys think this tri core or dual core will still be a lot nicer? main thing is to provide better performance at less power. Also is the HD2000 graphics good enough for playback
Going to be using
And
