seniorpaul
- Aug 8, 2005
The time has come to upgrade my monitor. My Hyundai L90D+ has served me well, but i want something with higher resolutions, and a little more screenspace. I've pretty much narrowed my choices down to the Dell 2405fpw or the Gateway FDP2185W. Let me first say that i have read a lot of reviews on both monitors, so i'm aware that each has some problems.
Dell 2405fpw
Gateway FPD2185W
I don't really care about inputs, as i'll be using this as a computer monitor with DVI cables only. I'm OK with the price of the 2405(as i know i can get it cheaper than tht price above), as long as i'm convinced that it is worth it.
Is there anything else that i should be taking into consideration? I think that right now i'm slightly leaning towards the Gateway, just because i can get it locally. In the event that there is something wrong, i have no problem making a scene in their store.
Dell 2405fpw
- more expenseive: currently around $950, although could wait for coupons or call Dell for discounts
- Larger screen size, higher resolutions: Definatly a plus, i've got the SLI'd 7800GTX's, might as well use them
- Dell's Return policy: might be a little harder to return if problems arrise...or at least be more of a hassle
Gateway FPD2185W
- Available Locally - can purchase at best buy and return/exchange if problems arrise
- Cheaper: $630 after tax - plus i have a $100 BB gift card, could try pricematching with CC's price
- HDCP - with Vista and new DVD technology coming, makes monitor more futureproof
