My OCing experience over the weekend. First build, first-time overclocking....
The computer's been stable at stock for a couple of weeks now, so figured it's time to try out what I've been reading/learning here.
Throughout the following, my RAM voltage has been set to 2.2V, and 1:1 ratio with standard 4-4-4-12 timings.
Using CoreTemp to measure temperatures.
First effort: Simply moved my FSB to 370. Made no other changes from stock and there I was at 3.3 GHz. Ran Orthos for about 2 hours to stress the CPU and temps were running at 42-43 C at load. Idling at about 20. I quit that test and ran a second one to stress both the CPU and memory. Ran this for a half-hour but had to leave the house and quit everything. Temps stayed consistent with the earlier test.
Second effort: Bumped the FSB to 390 for a speed of 3.5 GHz. Computer burped upon reboot so I upped the core voltage by two clicks, to 1.337. Again ran Orthos to stress the CPU. Load temps were 46-47 and idle about 22. Just ran Orthos for an hour and figured I'd get back to it the next day.
Third effort: Screw it. Rather than continue at 3.5, I bumped FSB to 400 to get me up to 3.6 GHz. Did not change the core voltage from my second effort. This time had most of the day to run Orthos. Load temps were in the 47-50 range, and do not think they ever got above 50. Idle was at 23-25. This time however, Orthos crashed at 24 minutes. I let things settle down a bit and restarted Orthos without making any changes. Orthos ran for 7 1/2 hours until it crashed. Had it not crashed I would have run it overnight.
So, what to do? Should I bump up the core voltage by one click and see what happens?
At what point to you consider the Orthos stress test to be successful? I know that some people will only take a 24-hour test as a sign of stability.
steve
steve
