So this may be a simple problem and I've searched but couldn't find a solid answer or solution. So in my pc I have a Raid 0 setup with two 500 gb samsung drives. When I first installed them I did a clean install and partitioned the Raid 0 setup (180gb for os) and the rest for everything else. So on my computer it displayed two separate drives. I recently bought an Evo 250 gb SSD and moved everything from my old C drive to that drive. Then I wanted to join the 180gb partition to the 751.51gb partition. I was successfully able to do that, however my computer still thinks that I have two separate drives. It still functions as one but I may suffer from a little OCD and I'd rather have it display as one whole partition.
So is there a way to have it display as one disk and one d drive? Also why does it say dynamic instead of basic? Is that what could be causing this? I forgot how I first made the partition whether it was through the windows disk or what (running windows 7 64 bit btw). I'm thinking maybe I have to format the drive and then convert it to basic but I don't want to have to do it and then find out that I still can't join the two for good. So has anyone else had this problem before?
