sweetvar26
- Apr 19, 2010
Did anybody get these shipped to Canada yet? I tried to email the seller but I haven't got a reply back.
Does this monitor got grainy and sparkle screen?
3008WFP does not have sparkle effect. It is a far superior display than 3007wfp-hc.
I have two of these 3008wfp monitors from precisiontechexperts (with a third one still inbound any day now) and neither one has had the warranty show up and be valid on the dell support site right away. The Dell support site said that the first monitor's service tag was invalid. I sent an email to precisiontechexperts (through ebay) and it took them a couple of days to respond, but they finally did and said they would take care of it. A few more days after that and they had the issue fixed. The Dell support site now shows the service tag of the first monitor as being not only valid, but also having two years + two months of advanced replacement warranty left. GREAT!
As for the second monitor, its service tag shows up as valid but it shows as not having any warranty at all. Yesterday I sent another email to precisiontechexperts about this second monitor's warranty but haven't received any response yet. I'm sure they are going to help me though. I'll report back when the warranty issue is fixed.
Oh, and they are both beautiful monitors with no dead pixels and no other problems that I can tell. And I don't notice any input lag playing fast-paced FPS on this monitor. Though, I should say that I'm only a casual FPS player so maybe I'm not attuned to that sort of thing.
Has anybody tried buying more then one at a clip from this guy? I bought one and want to get one more but I would guess he adds you to a block list for 10 days or something. What is the reasoning behind blocking someone? I have a perfect rep and pay instantly. Also this guy is not the fastest to respond but it looks like that is par for course although as long as i get my monitor i could care less ill wait another 10 days then.
Don't expect to ever get a tracking number though, it won't happen.
If you look real close on a bright green BG you can see the "sparkle effect." Anyway, the 3007 suffers from this problem to a greater degree. When I had my 3007 I noticed it on pretty much everything apart from dark colored backgrounds. Chances are they applied a thinner layer of coating on the 3008WFP.
I got my 3008 today. Its a refurb. Comes with nothing except the panel. No power cord and DVI cables.
I been playing for few hours now and the 3008 screen is much better than 3007 as far as AG coating. I can still see a little. I am trying to compare the 3008 vs the Dell 2405 from 2005 and see which flare better on the AG coating.
Agreed. Did you notice that 3008wfp offers much sharper image quality.... Still, I cannot complain about getting the 3007wfp-hc from them for $650.
Just send the guy an email and he will take care of that. Usually he will send dual DVI + power + USB uplink cables.
Mine is refurb as well but it looks brand new and in perfect working order. Also, just use the method mentioned in this link to check the hour
http://josh.st/2008/05/02/dell-2707wfp-lcd-monitor-service-menu/
Does anyone know if the 3008WFP supports 2560x1600 over HDMI?
My laptop doesn't have DVI, but supports 2560x1600 over HDMI1.3.
I went to Dell Support website and look for 3008WFP drivers and there are none. How do you all get yours? My refurb from ebay comes with nothing except the monitor. How to get the drivers? Thanks!
Yah, I was directly in Dell website and there are no files there. I do a google search and I found it and its like your path also. Thanks!
OK, I unplug all my monitor except the only one and I went to Control Panel and do a driver update on the Display. Got the 3008wfp on it.
Do a reboot and unplug/plug my monitor also.
Did the 3 button button and still doesnt work. Did Dell disable mine?
I email the seller again and ask him about my Service Tag which comes as invalid.
