I recently acquired my first rack-mount piece of equipment that I got for free from craigslist. It's a Dell PowerEdge 4400 rack mount server that supposedly still works, but I haven't tried it yet. The guy said it had dual PIII Xeon 833 processors and 8gb of memory with a RAID 5 array. I haven't dug into it yet to see what the hardware looks like inside, but given that this is the first time I've ever looked into a server part I think I'm going to need some help figuring out what to do with it. Since this is more of a rebuild than a scratch build, I'm not sure how much of the mandatory questions will be relevant but I'll try my best:
I'd like to use this as a home data server to back up my wife's photography work (Mac based) and my media files (Windows based)
Budget is undetermined at this time, but I would prefer to spend as little as possible to start. If I need to do a more complete rebuild, it probably won't be for a while but I would appreciate any suggestions that can be done for ~$600 (less storage drives) anyway.
USA, near Tucson AZ
As mentioned, I was told the system works so I don't think I would need anything at this point other than maybe some additional storage drives and software. If I rebuild, I would need whatever it would take to turn a working desktop (I have a spare) into a server.
The stock parts in the server. My spare desktop has an Antec 650w PSU I can pirate if needed.
6) Will you be overclocking?
No.
1920 x 1080, 23"
I have the server box already.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)?
etc.
I would like to keep whatever would be a good RAID configuration for data backup. Probably a RAID 1 or 5 which will eventually incorporate four 2tb drives.
I have Windows XP Pro (32-Bit), Windows Vista Home Premium (32-bit), and the Windows 7 upgrade for my Vista copy.
My internal debate is whether to try configuring this thing to work as a server, or if I should just gut it and mod it to fit normal desktop parts. Like I mentioned though I've never messed with a server part before so I came here to ask the experts. I made a post in the case mod forum with some pictures of the thing but thought maybe I should try asking for help in a section more geared toward hardware and function over aesthetics. For reference, the post is here.
USA, near Tucson AZ
No.
1920 x 1080, 23"
etc.
