Here is the scenario:
The Dell SC420 goes on sale all the time for $300 with a 2.8GHz P4 520. The SC420 uses a server version of the 925 chipset, I think. It has a PCIe x8 slot that can easily be modded to accept a x16 card. So this has me thinking, Gaming rig in disguise.
Here are the questions:
1. Can I wire/solder mod the P4 520 to use 1066FSB as the default? (BSEL for 6xx and 5xx for 200MHz FSB is identical, BSEL for 266MHz is listed as reserved on 5xx datasheet)
2. Assuming #1 is a yes, will the chipset on the SC420 run with this config?
3. Assuming #2 is a yes, will the chipset on the SC420 auto adjust the ram/PCIe divider based on SPD and default 100MHz PCIe? If not(on the ram), am I better off buying PC2-3200 (400MHz) that can most likely scale to 533MHz with ease?
6xx datasheet: http://download.intel.com/design/Pentium4/datashts/30638201.pdf
5xx datasheet: http://www.alienware.com/product_detail_pages/area-51m_7700/PDFs/30235102.pdf
