Einhanderkiller
- Aug 6, 2006
I can tell just by looking at the pic it will be crap.
Go ahead and elaborate a little if you are going to pass judgment; I am dying to read your mythical wisdom on the matter.
I believe that Wattman just made a funny. Atleast I thought it was funny.
Care to explain the architectural flaws you see? Thought not... people like those at Beyond3D can glean a lot from the die shot but not you .
Well, it's difficult to see from here, but I'm pretty sure they have the transistor arrangement all wrong. They have a couple of superfluous NAND gates in the lower left corner, too.
No one else did.
So is Larrabee essentially a group pentium 1-like cpu's put together to act as a gpu? How many cores are going to be on one card?
Wasn't the P1 made of a couple of 486s stuck together?Yeah, it's supposed to be a bunch of P1's stuck together.
I never thought I would see a die shrink of a processor from 1993.
No. http://en.wikipedia.org/wiki/Pentium#Improvements_over_i486Wasn't the P1 made of a couple of 486s stuck together?
Very roughly, I'd be careful making that kind of comparison.So is Larrabee essentially a group pentium 1-like cpu's put together to act as a gpu? How many cores are going to be on one card?
of course when people cant figure out design improvement they will try to make stuff smaller and stick a whole bunch together.
--wikiThe x86 processor cores in Larrabee will be different in several ways from the cores in current Intel CPUs such as the Core 2 Duo or Core i7:
* Larrabee's x86 cores will be based on the much simpler Pentium P54C design which is still being maintained for use in embedded applications. [9] The P54C-derived core is superscalar but does not include out-of-order execution, though it has been updated with modern features such as x86-64 support, [8] similarly to Intel Atom. In-order execution means lower performance for individual cores, but since they are smaller, more can fit on a single chip, increasing overall throughput. Execution is also more deterministic so instruction and task scheduling can be done by compiler.
* Each Larrabee core contains a 512-bit vector processing unit, able to process 16 single precision floating point numbers at a time. This is similar to but four times larger than the SSE units on most x86 processors, with additional features like scatter/gather instructions and a mask register designed to make using the vector unit easier and more efficient. Larrabee derives most of its number-crunching power from these vector units.[8]
* Larrabee includes one major fixed-function graphics hardware feature: texture sampling units. These perform trilinear and anisotropic filtering and texture decompression.[8]
* Larrabee has a 1024-bit (512-bit each way) ring bus for communication between cores and to memory.[8] This bus can be configured in two modes to support Larrabee products with 16 cores or more, or fewer than 16 cores.[10]
* Larrabee includes explicit cache control instructions to reduce cache thrashing during streaming operations which only read/write data once.[8] Explicit prefetching into L2 or L1 cache is also supported.
* Each core supports 4-way simultaneous multithreading, with 4 copies of each processor register.[8]
Intel = innovationof course when people cant figure out design improvement they will try to make stuff smaller and stick a whole bunch together.
They stated last year that it would have around the same performance as an 8800 level geforce. Since it's coming out in mid 2010, I'd have to say that it will become more like what the X3000 series is now... just good enough to keep nVidia and ATi from getting more IGP market share.
except for the fact that its not an IGP and is a discrete video card.
Intel = innovation
Intel = evil corporation!
What does that make AMD then with x86 debacle, eh?
So short the memory of the young masses...
