Jarod888
- Dec 19, 2005
Ok I have made all my purchases, and I have everything ready to be put together.
System will be as follows:
DFI LANPARTY UT NF590 SLI-M2R/G AM2
AMD 6400+ Black Edition
OCZ DDR2 800 PC2 6400 LanParty optimized memory
XFI Fatality sound card, (being pulled from the current system)
EVGA 640-P2-N827-AR GeForce 8800GTS 640MB
Raptor X 150 gig HD.
LiteOn 20 IDE DVD burner
PC Power and Cooling Silencer 750
There will be other harddrives and such added after the system is sound, but this is the basic build.
How should I go about putting it all together, what tests should I run and if I need to update the bios how can I with out a floppy.
Does anyone have a step by step guide to putting this altogether, and also any guides as to what to set in the bios. I will not be overclocking so any guide to that effect won't be all that helpful. I have built many computers before, but I have always used ASUS boards and they have been pretty much plug and play, no real issues.
I am slightly less confident of my abilities when building a DFI setup because of all the tweaking that seems to be required.
Also should I build everything outside of the box and then put it in when it is running well. I have never had a case with a MB tray and now that I have one with a MB tray, I would like to see if it makes everything easier.
Also where is the best place to make sure I have all the appropriate drivers and such, I have my current computer up and running so I can burn everything to cd before I start.
Also do you all think it is worth it to make up a build cd, by extracting XP off of my original cd and adding sp2, and all the hot fixes to it plus, adding in a folder of all relevant apps that I will need, and if you all think that is a good idea, can someone point me to a site that shows you how to incorporate hot fixes into a bootable cd. Thanks!!
