Soymilk said:the rs482 has integrated x300, not x200. not sure if that makes a difference in what u said about the 6150 being a little better or not tho. unless thats what u meant w/ the 200xpress, but that looks like x200 to me
buzzly said:With an Opty 144, it seems that the max bootable fsb is around 313-314 fsb regardless the multi or vcore settings. It is not as high as some reviews have indicated. But I'll take it. Once it's booted into Windows, I can use Clockgen to push the fsb to around 318 and still Prime stable. With an Opty 165, the max bootable fsb is around 305, regardless the multi or vocre settings.
The voltage is rock steady, unlike most of the mobos I have worked with. That may be one of the reasons why this mobo overclocks so well. I am using a 20 pin 450w PSU.
I am now convinced that the Smartfan is NOT for overclocking at all as it sets a very lazy fan speed. Hope there is fix in a future bios.
I still have not touch any of the memory settings as I use a set of cheap Patriot 2x512 sticks.
Also I have not spent time on fixing the connection to my HDTV via the DVI-D port. I may have to use Powerstrip to get that done. That sucks.
Also got a quick reply from DFI about the broken tab in my Component Output cable. Bascially, they tell me to rma the whole thing back to the reseller and don't brother them. That's suck becuase I don't want to wait for weeks. Time to bring out the Krazyglue.
That's it for now.
Anyone want to buy my Biostar tForce-939?
LxT said:I'm weighing b/t this board and the MSI K8NGM2-FID.
CRaZYMoFo said:Im planning to order one of these soon. Will there be any issues with using a 20pin PSU with it? I know it is 24pin. I do plan to OC. I have an Opty 144 Cab2e waiting to be popped in. The PSU I plan to use is an Ultra XConnect 520W v1.
CRaZYMoFo said:at what voltages?
Jen said:recieved my dfi board today
wont be able to test till i finish with this case
hugs
Jen
buzzly said:There have been two beta bio released already. It seems like DFI is cutting back some of the features in these bio releases, especially in the VGA Sync area. Also I have yet find the Surroundview in the bios (but it is in the manual).
CRaZYMoFo said:nice@ stock V
im putting mine under a 7000B-Cu
are the ocing options being affected in these new bioses?
From what I've gathered so far
DFI RS482: OC well, has all the HTPC features (component) of the MSI + SPDIF out (MSI requires bracket not included), though I won't be using SPDIF anyway.
MSI pros: not much OC (max 250 fsb, max 1.4v vcore). SATA II not SATA I (probably makes small real wold difference). 6150 video is a bit better than 200xpress. HD audio (I think the DFI does NOT have HD audio.) With PureVideo, it can playback 1080i mpeg2 and wmvhd smoothly with little CPU load. The 6150 also has vertex shader. It's also 15-$20 cheaper.
The ATI chipset is known to be not as good. The benchmarks show it lags behind on everything by 3-7%
http://www.xbitlabs.com/articles/chipsets/display/gf6150-gf6100_12.html
Of course that's with a ECS board, not DFI.
USB is known to be poor too. This'll be a problem as I may use a USB-based TV card.
Basically the DFI has one thing going for it: OC.
Some questions:
1) can you play HD (1080i mpeg2 .ts files, 1080p wmvhd) smoothly with the RS482 onboard video? Does ATI have something like PureVideo?
2) has someone done some benchmarking (e.g., Sandra, PCMark) to see how this board fares compared to nforce4 boards?
3) I was not crazy about the MSI's text output. How's text on the DFI? Does ATI generally have better 2D than nVidia?
4) When I had the MSI (which I had to RMA due to bad IDE controller), I pushed my X2 3800+ to 2440mhz stable on stock voltage (1.35v). Do you think I can push the X2 much higher to make it worth it to get the DFI, considering the drawbacks of the ATI chipset?
Jen said:cant someone just hack this bios for us and open up all the options . let us decide what works best.....
hugs
Jen
JWilson said:Hi Jen,
The 82DMD308 Mod BIOS with all options visable is here:
http://www.rhcf.com/sis-bin/ultimatebb.cgi/topic/31/210.html
Jen said:flashed to this bios and system now fails to post
i'm attempting to clear the cmos in hopes it will survive this
if not i am wondering if i can reflash the bios chip useing my jetway board
sigh
buzzly said:That sucks. Let's know how it turns out.
JWilson said:That corrupt BIOS was removed from that website. But not before I killed my board. I "HOT Flashed" the BIOS chip using a DFI nF3 Ultra that had the exact same chip. To do a hot flash on another system you must execute: AWDFLASH correctbios.bin /F
The "/F" tells the flasher to ignore that the BIOS is not for that board....
Sorry I brought this problem to your attention....
CRaZYMoFo said:Got my board today and its up and running now. Working fine so far. Going to test my ballistix sticks on it
Im not flashing the bios even though I am running an opteron 144 on it. Will wait for more official bios updates.
Now I really need to save and buy a qpack quickly
LawGiver said:why exaclty are we updating bios? Which ones does opteron need?
buzzly said:There is a very thin line between brave and stupid.
JWilson said:Your a brave man! Especially after Jen's flash of the corrupt BIOS and dead board... I'm working with her to get her board back on the air... I fixed the mislabeling on that BIOS page... Thanks!
