I just came across 2 boards that look almost the same on Newegg: The ABit AN8 and KN8. I'd like to know what exactly is the difference between the two boards.
ABit nForce 4/Ultra boards
SilverMK3 said:The AN8 is part of the Asus "Ai" lineup so it has a few extra bells & whistles.
GForce64 said:Are there any major stability issues with the AN8 boards, or are they as solid as ABit usually is?
TheRapture said:Rock solid once you get it dialed in with your ram timings...AND use the latest Abit BIOS...especially if you have an X2 cpu. Oh yeah...DO NOT use the Nvidia Forceware IDE drivers...
