Hi all,
I have a bit of a dilema..
Background:
My Onkyo receiver TX-DS696 is now slightly broken in which the center channel will not decode anything (totally silent), but if I use the 5.1 pre-amp analogue inputs the pre and power amps still work just fine. This is a really nice receiver so I do not want to toss it yet. I only need 5.1, and do not plan on going 7.1 anytime in the future.
My HTPC (LG Blue Ray ROM, ATI 2600 pro (with DVI / HDMI), on-board HD sound) has been connected to the receiver via coax (so I am not gettting Dolby HD codecs by default), and of course the center channel does not play. I am also using Total Media theatre on this box.
Instead of upgrading my receiver at the moment, I am thinking of dropping in an X-fi sound card and outputting the downmixed analogue 5.1 into my existing receiver and calling it a day..
I just bought a Yamaha receiver that natively decodes all the newest Blu-ray codecs, but sound quality is just not as good as my old Onkyo.. I kind of want to avoid buying a new receiver since it will be obsolete in 3 years with new codecs and won't be upgradable, so I can simply upgrade my soundcard / hardware as neccessary and use the analogue input to listen to sound...thinking about taking it back to BB. I don't really care about HDMI switching since I really just use my TV for all that.
1.) Should I keep my current hardware and get a better (Xfi?) soundcard to send 5.1 analogue to my current Onkyo receiver ?
2.) Will I run into any caviats with Total Media Theatre?
Any advice would be appreciated.
Background:
