I've had the Auzentech Forte for a few years now. It replaced a perfectly functional X-Fi Fatal1ty, but I need to see if I could improve my sound. Every since day one It has buzzed depending on GPU usage, and the sound would also corrupt every now and again. The sound quality was an improvement over the Fatal1ty, but the headache cost was too high. This is my second Forte after the first one decided to die after a couple months.
I decided I didn't want to deal with the crappy drivers anymore, so I just ordered the STX. I've installed both in my case side by side, and have a few thoughts on how they perform. I'm no audiophile, but I listen to a lot of music. The A900s were alternated between both headphone amps. The Forte plug is a lot more harsh on your headphone connector when try to remove your phones.
PC:
Core i7 950
12GB ram, all slots occupied
GTX 460
Gigabyte x58-UD3r
2x OCZ Agility 128GB Raid 0
The main differences:
- The STX caused the bios to load a few seconds slower, not a huge deal.
- No buzzing interference (I've tried the recommended tape trick, no go)! Complete silence when I have my headphones on. Thank God. The Forte was moved farther from the GPU also, but it still buzzed. No sound corruption yet either. I'm convinced that it was a driver issue since it happened more frequently when playing flash videos.
- STX has a much cleaner bass. The Forte sounds muddy in comparison. It's like the Forte is trying to fill the whole soundstage like a subwoofer. Unfortunately it recreates a cheap sub which booms at 100HZ no matter what note.
- The soundstage depth was similar, but different sounds didn't mix as much as on the Forte, a good setup.
- STX sounds similar to gaming with CMSS3D. Using the Dolby Headphone mode you can extend the soundstage a bit, but the fidelity suffers. Using Dolby Headphone on music makes it tinny and tries to recreate an echo on the more distance instruments, not my cup of tea. Using the 7.1 adjustment default causes the left channel to be louder than the right, I thought I was going crazy at first. Alchemy on the Forte might increase FPS, but nothing that I could notice.
- Being able to switch between speakers and phones through the control panel was a godsend. The front panel from Forte was an option, but the sound was terrible through the fronts.
- I have crappy logitech 2.1 speakers, but they still sound better with the STX in my opinion. This might be in my head since I don't use them all too often.
- The control panel no longer takes 8 seconds to load even on an SSD raid array! I miss the cool flying helicopter 3D effect though (no.. really).
- The midrange is more accurate, but this actually hurts if you're listening to low bitrate MP3s.
Bottom Line:
Does anyone want to buy a used Forte?
PC:
Core i7 950
GTX 460
Gigabyte x58-UD3r
Bottom Line:
