A new motherboard arrived last night (a Foxconn 748K7AA) so I began to install Windows XP (with SP1a). This was on a 40GB IBM drive (yes, a Deathstar, but with the firmware fix applied) that previously had Windows 2000 on it. Also, this drive also had only 9GB partitioned (I was going to do something with the rest but I changed my mind). I'm now using all 40GB as one partition.
The install went okay, once it was done I popped in my SP2 CD, and once that was done I visited Windows Update and got everything critical plus a few optional. Reboots in between everything as per normal. Only this error began after removing the Windows CD and starting the SP2 CD.
On that reboot, starting up again, I get a POST message:
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
and the only way I can get the system to boot is if I leave my Windows CD in the drive. I ignore the "Press any key to boot from CD....." message and Windows simply starts up. Otherwise I can't get past the error message.
For the record, I also have a pair of SCSI cards, an LSI 20860 and an LSI 8953U. I've tried booting to recovery console and doing fixboot+fixmbr but that didn't work. I can also try updating my IDE drivers, and as a last resort repair install or all-out reinstall, but I'm asking for any other suggestions. Maybe some BIOS or SCSI firmware setting...?
