lt_wentoncha
- Jan 20, 2005
Hi all,
I've got a nice three-monitor build going, 8800 BFG GTX OC2E driving the main monitor and secondary monitor and a paltry 8400 GS driving the last one.
I'm thinking long term if I want to go 4 monitors over DVI then I should probably get a 8500GT/8600GT...but heat and space is a major concern. I have an IP35 Pro, and a wireless NIC card is sitting right next the 8400GS (there's really no clearance, the cards are almost touching) so if I were to get a 8500GT or 8600GT would there be space? If so, does the 8500GT put out significantly less heat than the 8600GT? Because if it doesn't I'd probably pick up a 8600GT (it actually seems there's only one or two 8500GTs with 2x DVI).
8500GT:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814122031
8600GT:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150230
Anyone know if the heatsinks on those cards are small than their respective PCI slot covers?
8500GT:
8600GT:
