Well the best tool to use to OC you x1x00 series card is the Overclocking tool available over at DriverHeaven. There's a link bellow if you're like to test it. You can change tweak both the 3D and 2D clocks. Clso change the fan speed and the voltages.Antho_ie said:I know it's probably a daft question but both ATItool & rivatuner crash my system when I attempt any oc, but using overdrive I can get core to 660mhz no probs.... which is why I'm asking does it actually oc both cores?
