https://picasaweb.google.com/lh/photo/dwZRuvX-xx1Ar-3OONqSeC2bAvtzwWRq-ABajzriSaE?feat=directlink
After reaching 100% on pass 2 this happened. Bad ram?
That really depends though, in the OP's screenshot, memtest wasn't just failing the memory, it was full out failing. Not really a direct indication of bad memory.Don't assume the memory is OK just because it passes a different diagnostic. If it fails even one test when run with the right timings and voltage, consider the RAM bad, unless the author says a program bug caused a false positive. 3 passes isn't much, nor is a single diagnostic program.
Module manufacturers that don't manufacture chips don't do very strict testing.
